has any1 done this before?
From Taranaki, NZ
hey i got an old a12 engine sitting out my shed and alongside a pair of 40mm dellorto sidedraughts and an old turbo off my brothers gtx. in a few weeks im guna have a bit of spare time up my sleeve and was wondering has any1 turboed a car with twin side draughts? is there anywhere i can find a bit of information on this? anything will be helpful cheers
Posted on: 2004/8/31 9:09
Re: has any1 done this before?
yeah theres a bloke on here who has a supercharger set up through webbers!.. cant remember he dudes name on here tho.
Posted on: 2004/8/31 10:11
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From Christchurch NZ
Yes, Datsun 100A racer??? has done this. I think he is in finnland, or some thing. His is a blow through.
Posted on: 2004/9/1 8:10
Forced Induction!
From WA
i remember seeing on a japanese site a pair of nutter who took a liking to an SR20 in an S13.
they removed the EFI completely and retrofitted a pair of solex sidedrafts after the turbo.
it worked - not very succesfully by the looks of the dyno figures, but it worked.
anyways, why not look at using one of the carbies in a draw thru setup?
Posted on: 2004/9/1 8:13
From Okinawa, Japan
Yeah I'm told it worked really well on this:
And another example:
Posted on: 2004/9/1 9:48
is there an advantage using twin webbers over say a 32/36?
Posted on: 2004/9/1 9:51
From Albany, NY USA
Definately. Any downdraft carb on the stock intake will never amount to anything in the same league as twin side drafts. The side drafts make much more high rpm power.
Posted on: 2004/9/4 4:28
Not too shy to talk
From townsville
you cant use any old carby effectively on a blow through set up as they need a different seal set up on the shafts etc. also i think it ####s with the float and jetting? suck through you have to be carefull your inlet tract isn't to long or the fuel can drop out and you end up with pools of fuel in your pipework. big bang!!! go efi
Posted on: 2004/9/4 8:34
