CONRODS
Not too shy to talk
From Wanganui, New Zealand
I'm building up a balls out A12 but have no conrods. just wondering if i can use the rods out of a spare A12A motor i have and put them in a older better A12 motor? i assume they are the same but just wana make sure.
Posted on: 2004/9/3 1:13
Re: CONRODS
From Tracy ,Ca
yes you can use the a12a rods same distance center to center, beefier rod and larger pin bore 19mm versues 17mm for standard 1200.
I use the a12a rods in my a12 race motor.
although I am limited to .040" over bore you can bore most a12 blocks to 76mm and use an a14 standard bore piston which is roughly about a 1270cc engine and the bigger bore also
allows better cylinder head flow due to unshrouding of the valves
Bob
Posted on: 2004/9/3 4:47
Re: CONRODS
If you are going to build a "balls out" engine, you are probably better off starting with the A12a as a base. These came with a 75mm bore to begin with, so pushing it out to 76.5mm would just be the third standard oversize, & 77, or 77.5mm bore sizing would be easily achieved using standard Datsun pistons.
If you want to push it to 1453cc using standard Datsun engine parts, then drop me a line. This should be a doddle in the A12a block, but you will need those A12a rods.
Posted on: 2004/9/3 11:43
Love your Datsun.
Treat it well.
