Strut swap question
From Kingston , Brisbane
I know this has been asked a lot but I can't seem to get a straight answer by searching.
Do Sunny struts bolt in to the 1200's the same as 120y's do ???????
Posted on: 2004/9/12 13:10
Re: Strut swap question
From Western Sydney
As far as I know, yes, straight in.
Posted on: 2004/9/12 13:29
www.datnet.org
Fly by is that ur car in ur avatar its awsum!
I love it... tell me some specs etc on it.
Posted on: 2004/9/12 13:34
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From south australia
i have 120y struts brakes and booste in my 1200 there was a bit of modding for the booster though and it also has about a 12 inch gap between the front wheels and wheel arch ill have to do somthing about and the suspension is as hard as a rock
Posted on: 2004/9/12 13:57
From Brisbane Australia
yep they go straight in but u must get lower control arm and camber rod as the ball joint is bigger then a 1200 standard one allso u will need to drill the top of the strut tower out to 9 mm to take the larger studs of the top rubber
Posted on: 2004/9/12 14:43
From Taupo New Zealand
and you need to shorten the castor rods. I wouldn't bother fitting a brake booster, it's unnecessary.
Posted on: 2004/9/13 7:32
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
i didnt fit it the person i baught it from did it will be interesting to see how it stops
Posted on: 2004/9/13 8:44
From Western Sydney
woodydat, its a ca18det under construction
Posted on: 2004/9/13 9:42
www.datnet.org
Not too shy to talk
From townsville
whats the difference in stanza struts between year models as i was trying to get new ball joints for mine and there is apparently 5 different numbers to choose from mines got 2 bolts and are a bit bigger than the original 1200 ute ones.are there lower ball joints with four bolts? thought i read it some where. if so will the one i got do for rally or should i get a better model???
Posted on: 2004/9/15 3:45
