some question
hi every one there ....
i have this ute .. what i'm wondering is that what kink of spring that i can fit in for the raer that makes it stiffer and lower ...
i mean from wat car ... or model .....
i'm planning to put in a ca18 into that car ....
izzit a good idea ..... would it be alot of work..
and i'm wondering where can i find the datsun b110 ute manual book
Posted on: 2004/9/21 15:00
Re: some question
You have an [unknown] ute, & you want to make the rear springs stiffer?
Generally speaking, the rear springs in any commercial model are stiff enough, but probably not low enough. To get it down, some use lowering blocks, but i personally like to have the springs reset by a reputable spring works. This is a much better solution than trying to find another rear spring to fit.
I presume that you mean the CA18DE engine. This is a good choice, but to do it well, you will need to know your way around all the tricky bits that surround the fuel system, including the tank mounted fuel pump, & have the ability to work through the relatively complex issues of the electrical sustem & the computer.
It really is a fair bit of work involving chassis work, major fuel system changes, electrical work, body work, & some mechanical work.
Alternately, you will need the money to pay someone to help you through the tricky bits. I believe that some trans tunnel mods will likely be required, & when it's all done, you will need to get it engineered before it can be legally registered.
This is not really a job to be done in the back yard by an amateur & does not really come under the headings of quick, easy, or cheap.
If this is your first car, or first special car, then it might be a good idea to work yourself up to it by repairing & maintaining the ute first, then perhaps rebuilding the original engine, or upgrading to something more exciting within the same engine family. You will be learning all the time.
The CA conversion can come when you are in a position of being confident that you can finish it. In other words, just be carefull that you only bite off as much as you can actually chew.
The CA18DE is a good engine choice though
Posted on: 2004/9/21 15:34
Love your Datsun.
Treat it well.
Re: some question
thanks for ur advise .....
and yaa i'm sorry for not stating any model .. it's a B110 ute .... as u can see this is my first ute car and first time trying to convert a newer engine into an older car .... before this i have this SSS 510 but it is still running on original engine ang also my 310 station wagon ... so thats y i'm asking all this kind of question .....
but i find that the b110 rear suspension is abit soft and abit high too... and i'm from malaysia ..... here there is not much of this kind of car i mean b110 ute ... u can hardly see one at here in KL .... i think there is not more than 5 unit here ...
anyway i'm now doing up the body work first ..... then i try to figure out wat kind of engine to put in ....
Posted on: 2004/9/21 15:57
Re: some question
Hi dreamers,
You may find that lowering the sunny truck will remove a lot of the 'loose' feeling.
With a P510, a B310 wagon and a 1200 ute ... sounds like you have a vehicle for all occasions.
P.S: The truck version of the B110 is the B120. Newer ones are B122. The underhood chassis plate should tell the exact model.
Posted on: 2004/9/22 1:29
