Re: Carb specs
Try this for a quick diagnosis.
Remove the air filter & run your test again. If the problem dissapears, then replace the filter with a nice new one, PRONTO.
Half a mill above the dot in the glass is not normally a reason to pull the carb apart, but while you are removing the filter, have a look at the choke & make sure it is fully open. If not, fix that first.
Posted on: 2004/9/23 9:13
Love your Datsun.
Treat it well.
Subject Poster Date
     Carb specs datrat_dave 2004/9/23 9:02
       Re: Carb specs Dodgeman 2004/9/23 9:13
         Re: Carb specs ddgonzal 2004/9/23 16:01
