Rumbling Noise
From Brisbane
my car is making "rumbling" noise when decellerating or letting go off the gas pedal its like coming from the exhaust and carb (not 100% sure on noise on carby) but pretty sure the noise is coming from the exhaust
when you put the gear on neautral it doesnt make the noise
is it running rich?
checked the plugs, points, timing, fuel float seems right
running 32/36 weber on stock A12 engine
cheers
Posted on: 2004/10/5 0:54
Re: Rumbling Noise
From Toowoomba QLD
Razor wrote:
my car is making "rumbling" noise when decellerating or letting go off the gas pedal when you put the gear on neautral it doesnt make the noise
cheers
This would suggest to me that maybe the noise is in the gearbox?????
But I have been wrong more times than I have been right about these things, anyone else know different?
Posted on: 2004/10/5 1:46
Re: Rumbling Noise
From Brisbane
well right now you are right about you being wrong so thats a good thing for you....
well it wasnt making that noise before swapping carb from stock to weber
Posted on: 2004/10/5 1:53
Re: Rumbling Noise
From Christchurch, New Zealand
My first impression was gearbox too.
Posted on: 2004/10/5 2:26
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
Re: Rumbling Noise
From Brisbane
the noise was louder when I was running rich but now if I screw the mixture in further the engine runs rough
definitely not the gearbox though
was running fine before the swap
Posted on: 2004/10/5 2:29
Re: Rumbling Noise
From Toowoomba QLD
then my only other thoughts would be the exhaust is rattling on the floor or something similar. When you have it in neutral, it only idles and there is not as much movement in the engine mounts and it doens't hit????
( I think maybe I am just making $hit up now!!!)
Posted on: 2004/10/5 2:56
Re: Rumbling Noise
From Brisbane
I dont think its the actual exhaust though cos I did not have this problem before the swap.
Posted on: 2004/10/5 3:27
Re: Rumbling Noise
sup. how old is your muffler if it is hash that might be the confussion.any way check me out
Posted on: 2004/10/5 7:46
Re: Rumbling Noise
From Brisbane, Narangba
Could you explain the noise abit better?
There are alot of rumbling noises from a car you need to specify to us.
Posted on: 2004/10/5 8:02
Re: Rumbling Noise
From South Africa
Go under and inspect whilst someone revs the motor a little.
The closet part that exhaust system could hit on other than the body itself might the g\box.
Another thing { I could be wrong} is the brake pipes hitting somewhere near the body, especially if you removed them over the years a little.
Oh, another thing, could also been the g\box mounting rubbers are shot.
Posted on: 2004/10/5 8:03
Life's a bitch, so f...k it.
(1) 2 3 »
