#1 CANT GET THE AXLE OUT FROM MY DIFF
PVG070 Posted on: 2004/10/16 7:16
HEY IM PULLIN OUT ME CENTRE DIFF ATM< AND I CANT GET THE AXLES OUT< I UNDID THE WHOLE LOT AND IT AINT BUDGIN, WATS THE GO?
#2 Re: CANT GET THE AXLE OUT FROM MY DIFF
Autokat Posted on: 2004/10/16 7:28
You need to get 2 bits of wood or something similar ( about 1ft long ) put one peice each side of the axle in between the plate you onbolted and the diff housing and hit them at the same time ( like your rowing a boat ) they should pop out ...works on holden banjo diffs ( i blew plenty of them up in my Torana )
#3 Re: CANT GET THE AXLE OUT FROM MY DIFF
kegs Posted on: 2004/10/16 7:32
i had the same problem, ended up destroying the hub getting it out, luckily i was replacing the axle.
#4 Re: CANT GET THE AXLE OUT FROM MY DIFF
R-fastmotorsport Posted on: 2004/10/16 7:42
Hey PVG,
just put the brakedrum on backwards (so the surface the brake shoes run on is toward you) put a couple of nuts on (diagonally) about 5 or 6 threads and pull the brake drum towards you quickly. It will work as a slide hammer and shock the bearing enogh to dislodge the crud keeping it there.
Hope this helps,
Cheers
#5 Re: CANT GET THE AXLE OUT FROM MY DIFF
ang94541 Posted on: 2004/10/16 7:52
reversed-brake-drum-slide-hammer works for me everytime.
#6 Re: CANT GET THE AXLE OUT FROM MY DIFF
Autokat Posted on: 2004/10/16 7:57
I have to remember that one for next time ( never even thought about that )
#7 Re: CANT GET THE AXLE OUT FROM MY DIFF
PVG070 Posted on: 2004/10/16 11:11
Hey, thanx all for ya help. i worked out the problem, and it was still a bit tight gettin it off, a bit of rust was holdin it together there.. i've replaced the diff, but it aint the same. the back piece.. *sorry im not mechanically sound* isnt matching up with the tailshaft. i got the new diff out of another 1200, and yeah so what am i havin to do now? am i needing to replace the Tailshaft ? or the end plate of the tailshaft ?
#8 Re: CANT GET THE AXLE OUT FROM MY DIFF
R-fastmotorsport Posted on: 2004/10/16 13:20
Is the diff centre from another ute or is it a sedan / coupe one ? How many bolts hold the centre in place? Could it be possible to have a ute that someone has slipped a whole sedan / coupe assy under so they could rob the H165? Tailshaft flange should match if you remove ute centre and replace with ute centre! Describe what you have and we'll try to help !!
Cheers
#9 Re: CANT GET THE AXLE OUT FROM MY DIFF
PVG070 Posted on: 2004/10/16 14:49
Ok, im guessing that could be the problem.
I have a ute, and if i can remember when i went to Narangba Wreckers he pulled it out of a 1200 sedan.. they both have 4 bolts connecting them... it too late now, but i can even take a few photo's tomorrow morning and hopfully work out how to post. em on here...
#10 Re: CANT GET THE AXLE OUT FROM MY DIFF
dazzasute Posted on: 2004/10/16 16:08
another method:
grab a length of chain, and put the ends around the studs, and screw the nuts on to hold em there, thengrab a length of pipe, and wack the loop of the chain.
saves you hitting any of your car parts
