Slave cylinder
From Somewhere in OZ...
Just a question to clear up my confusion... The slave cylinder is for your hydraulic clutch isn't it? What do you top this up with? Mine has a leak in it...
Posted on: 2004/10/17 8:51
Re: Slave cylinder
From Perth
Brake fluid
Seals are cheap.......replace them
If its a 3/4" bore.....cylinders are cheap too.
Replace it........JB4055
Or JB4158 for 11/16"
Posted on: 2004/10/17 10:15
Re: Slave cylinder
Thanks for that man... I was kind of thinking brake fluid but its always best to ask isn't it.... Cheers.
Posted on: 2004/10/17 12:20
Re: Slave cylinder
From Melbourne,Australia
Iff its you slave cylinder that leaking thats the one on the gearbox your probally better off getting a new one there not that expensive but if its the clutch master cylinder there pretty easy to rebuild just get a seal kit good luck
Posted on: 2004/10/18 9:14
Re: Slave cylinder
From Warwick, QLD
Hey guys while we are on the subject of slave cylinders, do all slaves have the same bolt pattern??? As I need to get a smaller cylinder as the master isn't big enough for the slave I have and it's less work and hassle to maybe get a smaller slave. As when I press the clutch pedal, the clutch only dissengages whenthe pedal is right at the floor, there are no leaks in the line and it's been bled.
So when I press the clutch pedal the little rod coming out of the slave doesn't move too far.
Thanks for any help
Damo
Posted on: 2004/10/18 9:21
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Slave cylinder
Definitely not.
If you are talking about a hydraulic clutch slave cylinder for an a-series engine, look at this: Clutch slave cylinder comparison in our club photo album. These two appear to have the same bolt pattern, but others are different.
> As I need to get a smaller cylinder as the master isn't big enough for the slave I have.
Yes, if the bore diameter's ratio master/slave is too small you won't get much travel at the slave end. On the other hand it doesn't move much anyways.
TIP: Some Nissan transmissions need an external return spring for the slave. If this is missing it'll look like you adjusted it right, but it won't bleed out or adjust correctly. So force the piston into the slave by hand (takes lots of effort). Once it's bottomed out, add the spring, adjust the rod (1/16 inch play at the bellhousing) and try it again.
Posted on: 2004/10/19 3:51
