Re: PCV ...see you later>>>>>>>>>>>
From Auburn, Washington
I don't believe you're going to have a measurable difference in power between no PCV and a PCV. If you're getting that much oil up top, I think you've got other issues like rings or valve guides or a blocked line. An engine is nothing more than an air pump. All the air that goes in, has to go out. It moves around in the crancase too. A good PCV, good baffles and a good filter will do wonders and it will be virtually trouble free. Llike 240 said,no need to blow a hole in their ozone. That's my 2 cents anyway. Stepping off my soapbox now...
Posted on: 2004/10/19 1:51
Subject Poster Date
     PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/19 0:38
       Re: PCV ...see you later>>>>>>>>>>> B210sleeper 2004/10/19 0:51
         Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/19 1:18
           Re: PCV ...see you later>>>>>>>>>>> pro-240c 2004/10/19 1:33
             Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/19 2:33
               Re: PCV ...see you later>>>>>>>>>>> ddgonzal 2004/10/19 3:27
               Re: PCV ...see you later>>>>>>>>>>> chowdozer 2004/10/19 4:02
                 Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/20 4:03
                   Re: PCV ...see you later>>>>>>>>>>> pro-240c 2004/10/20 5:19
                     Re: PCV ...see you later>>>>>>>>>>> ddgonzal 2004/10/20 7:04
                       Re: Do 1200s pollute less than most newer cars? ddgonzal 2004/10/20 7:10
                         Re: Do 1200s pollute less than most newer cars? pro-240c 2004/10/21 2:17
                       Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/20 22:14
                         Re: PCV ...see you later>>>>>>>>>>> L18_B110 2004/10/21 1:26
                           Re: PCV ...see you later>>>>>>>>>>> Dodgeman 2004/10/21 15:15
                           Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/22 2:54
                             Re: PCV ...see you later>>>>>>>>>>> L18_B110 2004/10/22 4:40
                               Re: PCV ...see you later>>>>>>>>>>> ddgonzal 2004/10/22 7:22
                                 Re: PCV ...see you later>>>>>>>>>>> Dodgeman 2004/10/22 8:55
                               Re: PCV ...see you later>>>>>>>>>>> jaimecidpedro 2004/10/22 22:43
                                 Re: PCV ...see you later>>>>>>>>>>> ang94541 2004/10/23 8:17
                                   Re: PCV ...see you later>>>>>>>>>>> B210sleeper 2004/10/25 18:47
               Re: PCV ...see you later>>>>>>>>>>> pro-240c 2004/10/19 4:45
                 Re: PCV doesn't cause oil leaks ... ddgonzal 2004/10/19 5:53
                 Re: PCV ...see you later>>>>>>>>>>> ddgonzal 2004/10/19 6:41
                   Re: PCV ...see you later>>>>>>>>>>> pro-240c 2004/10/19 7:56
           Re: PCV ...see you later>>>>>>>>>>> chowdozer 2004/10/19 1:51
       Re: PCV ...see you later>>>>>>>>>>> chowdozer 2004/10/19 0:56
       Re: PCV ...see you later>>>>>>>>>>> ang94541 2004/10/19 8:28
         Re: PCV ...see you later>>>>>>>>>>> Rallytwit 2004/10/19 17:19
