Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Ignition Problems...
datrat_dave
Posted on: 2004/10/24 5:16
I am having trouble with my ignition and starter motor...
My car has been running fine for the past 2 - 3 months starting first go idiling o.k (only on cold mornings) but i have hit a wall in the past 3 weeks... It first happened when i drove down to our ovals at skool, i parked the car turned it off FINE. 2 hrs later went to start it up and got a low 'whine' and then just died out, tried again nothing.. Took of -ve terminal cleaned dizzy cap, cheked coil, leads all fine then looked at starter motor and twas fine aswell..Cheked fuses none blown and jsut let it sit there for 1 min. Tried again and it started fine! quite werid This happend to me about 1 week later, drove for a while stopped parked, turned off, BUT this instance it did start but it would jsut die on me if i didnt rev it and my battery lite was on even when i did rev it. went thru same process as b4 and it worked fine WEIRD!!! Happend again 1 week later, wouldnt start unless i roll started it to get the start motor moving, drove it home left till next morning and then started first go!! WEIRDDDDDD!!!! Has happened again today, started fine the smorning, everything fine sounding clean then when my dad came out it just died and i couldnt start it again, we roll started it and it went fine, parked turned off & wouldnt start....ARRG!!!!! PLEASE could some one tell me what the hell is wrong with my Sunny wagon!! I have suspision it is a bad terminal in the switch FROM the starter to the battery, i know that the starta motor tis fine... I have recantley just placed a Pioneer head unit and 4 speakers inthe wagon but it has never suffered from this problem until those incidents!!! I need ASAP, it needs to be running!!! Thanks tons Cheers Dave
#2
Re: Ignition Problems...
Posted on: 2004/10/24 5:50
Yes, I'd suspect the starter circuit of the ignition switch. Next time it won't start, use a voltmeter on the 'S' terminal at the back of the switch. If it reads less than 9 volts (with plug in place), I'd try another switch.
See Wiring. The B310 switch will be marked with 'S' so you can tell which is the the correct terminal.
#3
datrat_dave
Posted on: 2004/10/24 5:55
Sorry confused, are you saying the switch from the ignition? or the switch from the starter motor terminal? Coz i am getting electic power its just no power to the starter motor or dizzy etc...
Dave
#4
Posted on: 2004/10/24 7:09
The ignition switch is right behind the key cylinder, on the steering column. That's what I'd be looking at.
#5
datrat_dave
Posted on: 2004/10/24 7:47
Its not the starter switch from ignition, got one out of my other datto and i know for a fact thats fine, it must be the wires to starter motor or another terminal?? I took of starter and no movement but does get power to it....
WHAT NOW!!!!??? Dave
#6
Posted on: 2004/10/24 9:34
How do you know that the starter has power? I recommend using a voltmeter.
- The big wire should always have 12V. If you remove the starter from the engine, you can't easily test it as there is no ground wire - The small wire (S wire) on the starter should have 12V when the key is held to Start If you spot a problem trace it back: measure the voltage at the switch, at the fuse box, at the Fusible Link You know, it's nearly impossible to troubleshoot these kind of problems by writing about it ... the best way is to get a buddy who is good at this kind of thing to assist. You can view topic.
