Water temp sender
Quite a regular
From Melbourne, Australia
hey guys,
ive got a bit of a problem. my temp gauge sender is stuffed and im wondering how it comes out?? i took out the sleeve around the sender but the sender is stuck in there! how does it come out!!?! the motor is an a12.
Thanks!!
Posted on: 2004/10/26 5:21
Re: Water temp sender
It turns out just like a bolt. Are you saying the hex-shaped metal outside part broke off from the rest of the sender?
Posted on: 2004/10/26 5:43
From Stone Age somewhere in U.S.A.
take the sleeve out (the nut like thing) then grab ahold of the brass part with a pair of pliers and twist and pull, it will come out
Posted on: 2004/10/26 5:46
Quite a regular
well yeah that must of happened. that hex nut came out and i just thought it was a sleeve. what should i do?
Posted on: 2004/10/26 5:47
Quite a regular
by rgrinder on 2004/10/26 15:46:45
thanks ill give that a shot now! ill get bak to u
thanks guys!
Posted on: 2004/10/26 5:48
Quite a regular
thanks it worked!! cyah
Posted on: 2004/10/26 6:20
