#1 the reason i need double valve springs
nicholas Posted on: 2004/10/31 7:17
did a small sprint today and took a few picsOpen in new window
#2 Re: the reason i need double valve springs
Team_Dat Posted on: 2004/10/31 8:02
Just over 7 grand and 100kmh what were you in 2nd gear or something?
you have to love the revability of the A14
#3 Re: the reason i need double valve springs
Freak Posted on: 2004/10/31 8:12
Yeah you have to admit. Over 7000rpm on stock valve springs isn't bad. I hit 7300rpm the other day and still no valve bounce. I assume mine are stock as i didn't test their pound rate when I had the head done.
#4 Re: the reason i need double valve springs
nicholas Posted on: 2004/10/31 17:44
second gear on a dead flat road, not too bad but it could be quicker, maybe rev to 8k or so
#5 Re: the reason i need double valve springs
ddgonzal Posted on: 2004/10/31 22:48
Since you can rev to 7 or 8,000 rpm, why do you need double valve springs?
#6 Re: the reason i need double valve springs
Freak Posted on: 2004/10/31 23:20
What is your diff ratio? 100km/h in second. You must have a pretty tall diff.
#7 Re: the reason i need double valve springs
nicholas Posted on: 2004/11/1 5:06
well it i hit 7k it sounds like the motor wants to fall out the back so double springs will help me get to 8k easily. i think the ratio is 4.125 i might be wrong.
what are you guys going in second at that rpm?
#8 Re: the reason i need double valve springs
nicholas Posted on: 2004/11/1 5:10
when i hit 7k it sounds like the motor wants to fall out the back, that's why i need double springs so i can maybe get to 8k. i think the ratio is 4.125.
#9 Re: the reason i need double valve springs
Freak Posted on: 2004/11/1 6:12
It couldnt be 4.1 if your doing 100 in second unless you got some massive big wheels. I'm doing about 70km/h in second at around 7000rpm with a diff ratio of 3.9 and 13 inch wheels.
Also changing your valve springs wont allow you to hit 8000rpm unless you put in a bigger cam.
#10 Re: the reason i need double valve springs
nicholas Posted on: 2004/11/1 7:00
i think it is a 4.125 i'm running 195/70/14 on the rear and i have a 280 cam so it shouldnt be a problem
