« 1 2 3 (4)
Re: turbo hardware
I don't know the details but reckon it was a drag racing engine. I doubt if it would live long driven on the street at 31 psi.
Posted on: 2004/11/8 6:42
Re: turbo hardware
Quite a regular
From Burlingame , CA (near SF)
it must have taken alot of mods to his engine to pull this off very low compresion heads and pistons and a massive turbo that may have a a decent amount of lag im not sure but it had to have required a lot of custom fab work as well to pull this off but i do give him props for pulling it off
Posted on: 2004/11/8 6:49
Re: turbo hardware
There used to be a website for this car. Was called "The Worlds Toughest Little Car".
I dont think the site is active anymore, I will try and find it, it had some good pics of the car and engine.
Cheers Steve.
Posted on: 2004/11/8 6:58
Re: turbo hardware
what could be the highest psi i could run on the stock L20B..for it to last long????
do they have parts for the L20B that could allow me to run more boost.
Posted on: 2004/11/8 18:07
Re: turbo hardware
From WA
there are more aftermarket parts than i care to think about for the L series. and being in the USA you can double that number.
The Lseries have a very popular racing history - as do the A series - in the late 60s / early 70's.
on a stock standard L20 i wouldn't run anymore than 12-15psi with EFi, and no more than 10-12psi with a carby - mainly because a carby has more chance of falling out of tune and leaning out so you want to keep the boost down, just in case.
the L20s have open chamber heads as standard here in Australia, which lends itself to a lower static CR which is boost friendly.
Posted on: 2004/11/8 23:13
Re: turbo hardware
could you help me out..because i can't find anywhere on the net that has parts for my L20B..only stock parts.
If i run 10 psi w/slicks,and traction.what would be my estiamated horsepower/tourqe...and the most important the estiamated E.T on the quarter mile????????
Posted on: 2004/11/9 3:53
Re: turbo hardware
Quite a regular
wow there slow down and catch ur breath first off what do u have done already to ur motor heads, cam, intake, exhaust, tranny, diff?, it all factors in but with upgrded heads intake and of course turbo i am guessing around 200-230 hp to the rearand roughly 170-200 ft lbs of torque and to calculate your quarter mile is a little difficult to do so hope this helps late
Posted on: 2004/11/9 4:28
Re: turbo hardware
so what are your advise,or suggestions..
after all i'm a slite bigginer and want thinks to work...right
my uncle works at a machine shop so got that coverd..still need your guys EXPERTIES.
Posted on: 2004/11/9 6:15
« 1 2 3 (4)
