« 1 ... 4 5 6 (7)
Re: A Series? L Series? or CA?
From Brisbane, Australia
i attacked this conversion differently than what ive read here as i wanted the engine to sit as low as possible to fit downdrough webber and hat for future turbo conversion (not for a while). to achieve this i modded the crosmember, cut 25mm out of the centre and rewelded it giving me extra sump clearance
that's exactly the way I approached my conversion - engine as low and as far back as possible.
but the drag link is the same height as the x-member. And unlike the x-member, it rises when you turn the wheels. How did you get the sump to clear that?
aslo had to make spacers to drop swaybar down to clear oil pump
yep, me too.
trans tunnel needed no mods
auto tunnel, I assume?
used bluey clutch slave and rad as well, cut complete rad support out for clearance
just the opening in the rad support to accomodate the wider core, or did you cut the top of the rad support (where the bonnet catch is) too?
used l16 water pump and pulley to gain extra front clearance due to l20b having that hydrulic coupling
all 4cyl water pumps and pulleys are the same from wht I've seen, and I've used L16, L18 and L20Bs. Are you referring to the Bluebird viscous clutch fan? I simply threw the engine fan in the bin and use a VB/C/H thermo fan which mount in front of the radiator.
Posted on: 2004/11/10 4:29
From Perth Western Australia
I think mine sits further back, as I indented my firewall by about 20mm, but is probably slightly higher, as i haven't touched my swaybar. (It does have what I assume to be a 120y sway bar in it) I might have a few issues though, as the engine sits fairly close to it. How do you go about spacing out the swaybar?? just put some 10mm spacers in made out of aluminium plate or something?? (that shouldn't be hard... uncle works for a boat builder... )
Mine has a modified sump which helped with x member clearance. someone cut out the back half of it, and raised the back 2/3's of it by 10 - 20 mm. I can't see any problems with that, as long as i change the oil a bit more frequently.
Posted on: 2004/11/10 5:22
From WA
L18_B110 - there's no difference between auto or manual tranny tunnels in most datsuns (P310-11 and P410-11 are different) - the only cars with different tranny tunnels for autos are the K series corollas and early ford escorts / capris. even geminis have the same tunnel.
i am open to correction here but i would be VERY surprised if that were the case.
Posted on: 2004/11/10 6:57
From WA
i'd also like to let it be known just what a fantastic thread this has become. we should sticky it, or put it somewhere for future reference.
Posted on: 2004/11/10 7:44
i am open to correction here but i would be VERY surprised if that were the case. .
we're talking about Datsun 1200s here...
they do have very different trans tunnels.
Posted on: 2004/11/10 8:13
From Perth Austarlia
The 1.8 Litre L series puts out 104 HP standard. Whack on twin carbs and some extractors and you'll probably have about 115 HP. There are plenty of 5 speed gearboxes around, the boxes will handle 115 HP easily. Electric ignitions are a bolt on fit (series 2 bluebirds). The engines are torquey as. I hardly revved my engine past 3 G. most gear changes where at about 2.5G and this was enough to keep up with most modern cars. (My L18 was in a 1100 Kg car)
To get 115 HP out of an A15 may involve considerable cost. The torque will not be as good, 5 speed gearboxes cost s*@t loads. An A15 probably weights less than an L18 but the difference would not be much.
As for the CA18... forget it!!!! Doing an EFI conversion requires a lot of work and money. Save yourself the hassle....Whack in an L18 and have fun!!!
A normally aspirated CA18 may have more power (130 HP) compared to the L18, but torque wise, the L18 is probably pretty close to the CA18. (I'm not sure)
Posted on: 2004/11/10 10:51
From Perth W.A
I am currently in the middle of the L18 into a 120Y conversion at the moment and the L18 has a worked head and twin SU's, and so far the converison has cost me about $400 dollars and that includes a complete 180B sedan which was licenced and a set of stanza struts with 200B discs and i got the calipers later. i have a TRX 5spd behind it and i might even be able to use the 180B tailshaft but i'm not sure yet. must look into it. but wil let you know.
for $4500 you can have a nice slightly worked street rebuilt L18 with 5spd and twin carbs and everything else done including a decent interior for that kinda dough as long as you put in the effort. just be on the lookout for good deals.
Posted on: 2004/12/6 8:06
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
« 1 ... 4 5 6 (7)
