Re: Got the turbo carb today!!!!
150kw rear-wheel power from a stock A14? That's "bench" kw. (150 kw is 201 hp). Take 1200GXman's advice and get a dyno kw reading before and after.
2 bar is 28 pounds of pressure. Will a stock A14 block take this much -- even with lowered static compression? I'd think you need crank, rod and piston work.
Posted on: 2004/11/17 17:51
Subject Poster Date
     Got the turbo carb today!!!! nicholas 2004/11/17 4:59
       Re: Got the turbo carb today!!!! 1200GXman 2004/11/17 10:25
         Re: Got the turbo carb today!!!! nicholas 2004/11/17 17:10
           Re: Got the turbo carb today!!!! ddgonzal 2004/11/17 17:51
             Re: Got the turbo carb today!!!! nicholas 2004/11/18 4:52
