Re: Rear Disc Brake Setup
I have done some investigating for my self and have seemed to have found the problem. With drums there is a one way valve which is spring loaded and holds a certain amount of pressure in the break lines...(enough to hold the drum shoes out). With disc breaks you have a similar valve but with a small hole in the centre allowing no residual pressure. They are quite obvious when pulling apart a standard 1200 MC. I know there is a fair bit of fuss about upgrading master cylinders when upgrading brakes but could someone please explain why? I can understand the use of a booster but apart from that I can't see how it makes any difference.? There is the obvious variations in bore and stroke but shed some light....
Posted on: 2004/11/18 13:55
Subject Poster Date
     Rear Disc Brake Setup Datsun1200RallyCoupe 2004/11/15 12:21
       Re: Rear Disc Brake Setup 1200rallycar 2004/11/15 12:26
         Re: Rear Disc Brake Setup Datsun1200RallyCoupe 2004/11/15 12:45
           Re: Rear Disc Brake Setup 1200rallycar 2004/11/15 12:59
             Re: Rear Disc Brake Setup Datsun1200RallyCoupe 2004/11/15 13:25
               Re: Rear Disc Brake Setup 1200rallycar 2004/11/15 13:34
                 Re: Rear Disc Brake Setup Datsun1200RallyCoupe 2004/11/15 13:40
                   Re: Rear Disc Brake Setup 1200rallycar 2004/11/15 13:44
                     Re: Rear Disc Brake Setup R-fastmotorsport 2004/11/16 6:23
                       Re: Rear Disc Brake Setup Datsun1200RallyCoupe 2004/11/16 11:04
                         Re: Rear Disc Brake Setup Dodgeman 2004/11/17 9:58
                           Re: Rear Disc Brake Setup Daveman 2004/11/17 21:40
                             Re: Rear Disc Brake Setup datral_10 2004/11/18 2:14
                             Re: Rear Disc Brake Setup Dodgeman 2004/11/18 7:25
                               Re: Rear Disc Brake Setup Daveman 2004/11/18 13:55
                                 Re: Rear Disc Brake Setup Dodgeman 2004/11/18 19:50
                                   Re: Rear Disc Brake Setup Daveman 2004/11/18 23:21
                                     Re: Rear Disc Brake Setup Dodgeman 2004/11/19 9:55
