« 1 (2)
Re: Re: SU Manifolds
Does anyone have more information on using non-Datsun carbs with the GX manifold? The previous poster said HS2 british carbs will work (HS2 is 1.25 inch bore).
Has anyone ever used the H4 or HS4 MG carbs on a Datsun manifold? They have 1.5 inch bores which is very close to the Datsun sidedraft 38mm bore.
Of course, SWM still sells a GX-style intake manifold so it shouldn't be difficult to find all the parts.
Posted on: 2004/11/20 8:22
From Dallas TX
Hey Guys,
I'm also looking for the "SU" GX manifold (have been for awhile now). Please post info on possible leads!!
As for using other carbs on the SU manifold such as real Skinner's Union carbs (MGs etc), there are a couple of things to consider. I've found that if it's an HS4, 1.5" bore it will have the correct mounting holes, ie 3" centers at 45 degrees to the vertical (or horiz whichever). But the GX manifold has the 45 degrees running the opposite directions so you have to make sure the carb pair you find run the opposite directions. To help clarify that, on the GX the bolt angles are something like \ / vs / / or \ \ for some carb setups. On the other hand, i've seen very simple adaptor plates that can be used to bolt any carb pair to any manifold. It's basically a square with 4 holes at the 45 degrees spots on 3" centers. But you still have to be careful that you can fit the carbs to the manifold if they're not mounted in the preferred direction ie with the bowls facing "out" or away from between the carbs. Also there is something else to consider. Some carbs were designed to be mounted to the engine at 20 degrees or 30 degrees, so their float bowls will be angled to keep the bowl level when the carbs are mounted. I've heard that you can replace the bushings to set any float bowl from an angle back to 0 degrees, but I haven't tried it. As for linkages, you're on your own there. I'll figure that out when I get to it!
I don't know if the 1.25" HS2's will fit without an adaptor. The 1.75" HS6's are 4-bolt carbs on 3" centers (I just measured my Z carbs). So they will bolt up but only with 2 holes and the bores won't match.
Oh one plus to using real British SU's is that they have a LOT more performance parts available. Much wider range of needles etc. That's what I've found in my research anyway (which I'm still working on...)
michael
Posted on: 2004/11/20 22:15
SWM is Stewart Wilkins Motorsport and their catalog lists manifolds for A-series engine. There is a link in the Carburetor article.
Posted on: 2004/11/21 1:01
From Melbourne, Australia
i've got one i put in the classified a few week ago at AUD$150
still got it, who wants it?
Posted on: 2004/11/21 13:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Dallas TX
Will you sell/ship to the US? If so, I want it!
(it has the oval ports right?)
Michael
Posted on: 2004/11/21 16:19
« 1 (2)
