removing windscreens
From Perth, Australia
Hello all, im just wondering how hard it is to remove a windscreen, front and rear in a ute, and then replace it using the same rubbers. Is this even possible? I have never removed a windscreen before. What are the odds of cracking it with professional tools? are there professional tools?
Posted on: 2004/11/24 6:30
Datto 1200 ute undergoing rebuild... one day it will be finished. i hope. *FINISHED*
Re: removing windscreens
Posted on: 2004/11/24 7:03
From south australia
i dont know if its wise to take advice from an ameture like my self but
all i used was a butter knife to free up the rubbers then get inside and gently with force pushe them out with my feet
be sure to lay somthing softon your boot/bonnet eg mattres to catch the glass or even better a friend to catch it for you
then to put them back in get put the rubbers back on the wandow apply some window sealer get some thin rope and lay it all arount the grove in your rubber place the window in position and slowly pul the rope out from the inside the car this should pop the rubber back in
probebly confused the #### out of you but there you go
Posted on: 2004/11/24 7:08
From Sydney, Australia
Do it on a hot day, that helps a lot.
If it's old (> 5 years old) then there is a good chance that you'll wreck the rubber.
Get quotes on new rubber before you start, and make sure that they have them in stock. It could be a 2 week downtime on yuor car, if you don't plan for this.
Posted on: 2004/11/24 7:09
From Sydney Australia
RB20's way is the way the pros do it there are no special tools. Just be sure not to force it.
Posted on: 2004/11/24 10:12
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Perth Western Australia
uh... dd... that link is to this thread????
Posted on: 2004/11/24 11:03
From Adelaide
Can you still buy new windsceen seals for 1200 utes??????
Im in Adelaide..
Posted on: 2004/11/24 11:51
try adelaide restorers hot line on 384 south road richmond 08 83540900 they are allways advertising datsun rubber kits in the adelaide trader
Posted on: 2004/11/24 12:04
You can use the Search box?
Been talked about in detail earlier this year: removing windscreens
Posted on: 2004/11/24 16:15
