Re: A15 needs bottom end work.
From Auburn, Washington
Good info Dodgeman, as I'm finding that cams are a little hard to come by in the US. Thanks
Posted on: 2004/12/17 13:38
From Burbank, CA
nismo a12gx cam: M-13001-H2300
Is a later model A series cam for engines with the dizzy at the back?
I think I'm gonna source a newly rebuilt engine and get this one overhauled later, I'd rather not mess around with not having enough $$ to make it good.
I might have overrevved it. I was at about 50 in second gear, it was still pulling and didn't make a fuss till i shifted to third.
I'd get the cam reground if the nismo a12gx cam weren't $115. It's probably cheaper than a regrind.
Posted on: 2004/12/17 17:59
|||\ 81 KPB310 /|||
I'd be really interested to know if that cam works in an A14/15.
Posted on: 2004/12/17 19:32
From Burbank, CA
oh, it gets better... I've decided to just get a freshly remanufactured engine swapped in, so I'm gonna have them put the A12gx cam in it then, and then in the spring I'm thinking I'll convert it to propane so I can get out of smog check. maybe turbo then ;)
Posted on: 2004/12/17 23:19
|||\ 81 KPB310 /|||
From Brisbane, Narangba
Well over here in Aus I can get a cam ground for $70 so i couldnt see it being dearer over there.
Posted on: 2004/12/18 1:00
« 1 (2)
