nissan vanette
From ACT
hey guys,
ive been offered a nissan c22 vanette, and i know it has a h190 diff(i counted the bolts and it has 10) but i couldnt get a look at the engine, so i was wondering if anyone could tell me what engine it is running.
thanks guys
Posted on: 2005/1/12 10:14
Re: nissan vanette
From Newscastle, Australia
A15...
Posted on: 2005/1/12 11:34
Dont die wondering.....
Re: nissan vanette
From sydney australia
how to tell what engine it has.open drivers door(right side door).fold seat back forward if
possible.look under drivers seat belt where it
disappears into the trim.the silver plate that
should be there will tell you if its an a15 or an a12.it'll also tell you if it's a 4.1 or 4.6 diff ratio.
just look for h*41 or h*46.the number is the diff ratio.if you can't find a plate there,look under the drivers seat.there might be a flap in
the carpet,& under this flap will be the silver plate.this will mean it's an urvan,& probably
have a z20 or z24.it'll still have a h190,but the
axles will be the large variety.either a 4.1 or a 4.3.
Posted on: 2005/1/13 10:17
Re: nissan vanette
From South East QLD
what size axles dose a C120 A15 Vanette Have ? the Larger 28 spline or the smaller 23 spline the same as the H165 ? ...
Posted on: 2005/1/13 10:51
Re: nissan vanette
From Wellington New Zealand
same spline as the H165 in my experience
Posted on: 2005/1/14 0:21
Re: nissan vanette
From Bridgetown, Barbados. W.I
how strong are these axles in these rear ends? How big are the alxes? how much power/torque will they handle?
I'm thinking of using one but would like to know how strong it is first.
thanks
Posted on: 2005/1/14 2:24
Life's better SIDEWAYS!!
Re: nissan vanette
From Taupo New Zealand
ditto for me, C120 housings are very wide though.
Posted on: 2005/1/14 5:07
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
