Re: Them carburetors and jets
From Brisbane, Narangba
Firstly find out what your weber 32/36 came off. Mine came off a 1600 cortina which is pretty close in capacity to an a14. If yours is off a 2l cortina/escort then you will need to change chokes and stuff.
Mine is running 140primary and seconday although 1 appears to be slightly larger than the other and it works good. Not running too rich and not running too lean.
If the 32/36 you have is off a 1600 instead of a 2L you will be almost there as far as setting it up goes. If you put on one off a 2L without changing anything you will have storm clouds coming out the back.
Posted on: 2005/1/26 10:33
Subject Poster Date
     Them carburetors and jets Losadel 2005/1/26 6:54
       Re: Them carburetors and jets Freak 2005/1/26 10:33
         Re: Them carburetors and jets Losadel 2005/1/26 10:59
           Re: Them carburetors and jets Freak 2005/1/26 11:29
             Re: Them carburetors and jets nicholas 2005/1/27 5:09
               Re: Them carburetors and jets Losadel 2005/1/27 7:03
                 Re: Them carburetors and jets Freak 2005/1/27 7:21
                   Re: Them carburetors and jets nicholas 2005/1/27 8:49
                     Re: Them carburetors and jets Losadel 2005/1/27 10:57
