Re: help. cant get ball joints off
From Brisbane, Australia
you'll need to bash it good with a mini-sledge or something similar
You need a good ball-peen hammer for the job. The impact of the hammer needs to distort the taper of the arm (the part you're hitting) in order to pop it off the balljoint's shaft. The smaller contact point will require significantly less effort (and do less damage) to achieve this than a mini-sledge or club hammer.
On a Datsun strut front end, this process can damage the balljoint itself if the steering arm is not held securely, either by reconnecting the strut, or by removing the assembly and holding the arm in a vice. But it is unlikely you'd need to remove the arm from the balljoint unless you are replacing the balljoint.
Posted on: 2005/2/2 23:39
Subject Poster Date
     help. cant get ball joints off tom210 2005/2/2 7:57
       Re: help. cant get ball joints off pro-240c 2005/2/2 8:33
       Re: help. cant get ball joints off A14force 2005/2/2 8:34
         Re: help. cant get ball joints off converted 2005/2/2 8:49
           Re: help. cant get ball joints off ANGE 2005/2/2 8:56
             Re: help. cant get ball joints off dattodude 2005/2/2 10:36
               Re: help. cant get ball joints off LAGWAGON 2005/2/2 11:55
                 Re: help. cant get ball joints off datman55 2005/2/2 21:50
                   Re: help. cant get ball joints off L18_B110 2005/2/2 23:39
                     Re: help. cant get ball joints off pro-240c 2005/2/3 0:01
       Re: help. cant get ball joints off dattodude 2005/2/3 0:42
         Re: help. cant get ball joints off tom210 2005/2/3 12:17
           Re: help. cant get ball joints off L18_B110 2005/2/3 22:56
             Re: help. cant get ball joints off LAGWAGON 2005/2/3 23:00
