Re: good parts from stanza???
From sydney australia
get the diff centre out of it & fit it into you're
ute,that is if they're both h165's.don't throw
away the housing,either,cause someone on this site might grab it to put into a sunny (b310).keep the brake booster & master cylinder,because they can be used to put boosted brakes into the ute.it's a pity you're in
vic,because i'd grab the engine crossmember off you at least, probably the gearbox crossmember & the diff housing.the freight to sydney would be the killer,though.oh,strip all the nuts & bolts,clips,& pins off it before you
through it away.they're cheaper than buying them from a dealer.
Posted on: 2005/2/3 10:19
Subject Poster Date
     good parts from stanza??? ANGE 2005/2/2 10:28
       Re: good parts from stanza??? Anonymous 2005/2/2 11:07
         Re: good parts from stanza??? b310gx 2005/2/3 10:19
           Re: good parts from stanza??? ANGE 2005/2/3 10:28
             Re: good parts from stanza??? 1200rallycar 2005/2/3 10:46
               Re: good parts from stanza??? b310gx 2005/2/6 3:09
