good parts from stanza???
From Melbourne AUS
im about to get hold of a stanza sedan...
just wondering what parts would be good to salvage for my 1200??
also if anyone needs anything from it everything will be sold cheap as i can only keep it for a short while because i dont have the room...
it has an L16 and auto..
and its round headlight model so no girlock's im sorry...
Posted on: 2005/2/2 10:28
1973 B110 A12
Re: good parts from stanza???
keep the headlight and grill for a quad headlight treatment setup a la 1600
Posted on: 2005/2/2 11:07
From sydney australia
get the diff centre out of it & fit it into you're
ute,that is if they're both h165's.don't throw
away the housing,either,cause someone on this site might grab it to put into a sunny (b310).keep the brake booster & master cylinder,because they can be used to put boosted brakes into the ute.it's a pity you're in
vic,because i'd grab the engine crossmember off you at least, probably the gearbox crossmember & the diff housing.the freight to sydney would be the killer,though.oh,strip all the nuts & bolts,clips,& pins off it before you
through it away.they're cheaper than buying them from a dealer.
Posted on: 2005/2/3 10:19
From Melbourne AUS
yeah probably pull the whole rear assembly out... althought i dont know where im gonna put it all....
what ratio does the stanza run? thats if it is h165... i know my ute is...
Posted on: 2005/2/3 10:28
1973 B110 A12
From Melbourne, Australia
if anyone is intrested in converting to stanza headlights i have someone elses work where they were probably 80% along converting the grill to fit, that was actually for twin square headlight not the round though,
i rather stay stock so the car is easier to identify but if others like the idea.....let me know
Posted on: 2005/2/3 10:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
the stanza diff ratio is 3.7:1,which makes for much more relaxed cruising & better range from
a tank of petrol.
Posted on: 2005/2/6 3:09
