Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
will a12 stuff fit a15
74sss
Posted on: 2005/2/3 8:50
as you know i have a SSS. will the carbs manifold and extrators fit on an a15. or will the a12 head fit on to the a15 block.
i want some extra power
#2
Re: will a12 stuff fit a15
1200rallycar
Posted on: 2005/2/3 8:55
extractors only really, the a12 head yes but think its not as simple as a direct bolt on, would have to search for the info
the carb will also work, but not the inlet manifold, you could just swap the carb to the a15 manifold though, the a12 carb apparently does have bigger jets
#3
nzdatman
Posted on: 2005/2/3 8:59
this guy has a SSS so must be running 2 X 40DHLA Dellortos.
You'd be better to get an oval port manifold for the A15 head, use the dellortos, get the cam ground, plane the head, get it tuned on a dyno and then you've got a weapon mate!
#4
1200rallycar
Posted on: 2005/2/3 9:07
ooops sorry, scanned to quick mainly went off subject
but what i said still applies from the fact he's trying to use a12 gear im guessing he doesnt want to spend that sorta money but still good advice maybe boost if for a similar cost
#5
Frodaddy
Posted on: 2005/2/3 9:28
Did the 1200SSS have round port heads?
#6
74sss
Posted on: 2005/2/3 18:09
i dont mind replacing things if i have to but with the twin carbs attached to the a12 while sitting on the workshop floor seams a waste.
the 1200SSS had a standard head. You can view topic.
