Team_Dat wrote:
yes when using nissans ingeniouse front mount holes for te Lseries they forgot to take the cowling into account
Not sure what 'cowling' you are referring to, but I guess you mean the radiator support panel? Here is the 120Y coupe I did the swap on, and you can see the rad support is cut out to suit the larger rad. I used a Volvo 244DL radiator. This took about 1/2 an hour to do. You may have had to cut out more or less depending on the radiator you chose to use, and would have also had to come up with a way of mounting the radiator. And don't forget you'll have to find suitable radiator hoses too.
Team_Dat wrote:
and also the fact the gearstick selector is 2 inches behind the gearstick hole in the tunnel and little things like that, more cutting than i would have hoped for.
a stumpy box's (R30 Skyline or Stanza have short 5spds) shifter fits in the original floorpan hole on the 120Y which has a long oval opening to suit the L14 and L16 variants they were released with in other markets. Sounds like you used a long box...
Pro-240c wrote:
LOL and the fact that you have to grind about 3inches off the 180B crossmember to clear the castor arms mounts.
Here's a photo of the 120Y and 180B x-members. the part that fouls the castor rod brackets is where the x-member mounts to the chassis. How did you manage to bolt the 180B x-member on after removing 3" off it?
You should have cut about half to three quarters of an inch off the castor mount brackets, like this...
All these pics were already on the site and linked from various discussions on the L series conversion into the 120Y (B210). And all the 'problems' you've raised here have also been covered in those discussions. Maybe you guys should have used the search function? But at the end of the day, asking a question here, or any other web forum, does not mean you no longer have to think for yourself. In any conversion, you will need to consider things like larger rads, gear shift position etc etc...
