jerking problem?
From durban, south africa
hey guys with my volksan i've got a problem when doing between 60km/h and 90km/h the car jerks, just a light jerk but you can feel it! this problem has only started since i put sone -ve camber on it, and when i put people in the car i gets worse.It's only when i'm on the gas lightly that it happens if i lift off it goes away, but it only happens between 60-90 in 3rd and 4th gear
Can anyone shed some light? Open in new window
Posted on: 2005/2/9 5:23
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: jerking problem?
From Sydney, Australia
You may need to reengineer your rear suspension. Sounds like the drive shafts universal joints are "binding up". At speed, the rear of the car might get pushed down due to the volkswagen's aerodynamics.
The fact that it gets worse with more people in the car, gives support to my theory.
Raise the back for a little while and see if it continues.
Chris
Posted on: 2005/2/9 5:40
yeh if i take it up it goes away, but the car doesn't handle! how would i fix that problem?
Posted on: 2005/2/9 9:42
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
