a15 v's e15
Quite a regular
From newcastle
does the e15 bolt up to the a15 gearbox? or any other rear drive box? has this been done before in a ute or coupe????ken
Posted on: 2005/2/13 11:35
Re: a15 v's e15
From Adelaide, SA
I've heard it bolts up with the exception for one bolt - use the search button on the left for more info.
TC
Posted on: 2005/2/13 11:42
Re: a15 v's e15
Quite a regular
From newcastle
if they do bolt up whats the go with clutch and flywheel??has it been done before???
Posted on: 2005/2/13 11:56
Re: a15 v's e15
Think about where the dizzy sits on the E series.............
Posted on: 2005/2/13 12:25
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: a15 v's e15
From T'ville
the dizzy is easy fixed
just like most things you will probably be the first
so get your trusty ruler out and start measuring ,do you have an e15 ? if not get a cheap (stuffed one ).
Posted on: 2005/2/13 14:04
