#11 Re: brake upgrade
rally-a-coupe Posted on: 2002/6/15 8:49
They are in NZ but the have to be able to hold a car on a 45 degree angle so you have to have a locking mechinisem
#12 Re: brake upgrade
bent_axel_bob Posted on: 2002/6/15 15:13
well that sounds easy enough will have to find out if its legal in oz would sure make a rear disk brake conversion easer not haveing to worry about cables and crap
#13 Re: brake upgrade
stirlingmac Posted on: 2002/6/16 3:51
As a certifier I would like to know who in NZ will certify a car with a hydraulic handbrake. They are illegal for road use. You may apply for dispensation though the NZ Motorsport Association but unless the car is used in competition regularly you'll be out of luck. The reasoning right or wrong is that in an emergency ala loss of hydraulic pressure the mechanical handbrake can be used to stop the car. I have argued unsuccessfully for years saying that a separate hydraulic circuit for the handbrake should be OK but to no avail. I built a Datto coupe a few years back for a friend that had a hydraulic set up that used the stock handbrake and cables actuating a master cylinder hidden in a box in the floor behind the drivers seat. He ran it for nearly three years before it was spotted and I got a rap over the knuckles for doing it!!!
#14 Re: brake upgrade
rally-a-coupe Posted on: 2002/6/16 4:46
stirlingmac it would be fully legal in a rally/race car with a current Motorsport Authority card but in a street car it would be ILLEGAL right .
#15 Re: brake upgrade
bent_axel_bob Posted on: 2002/6/16 4:52
thats queer hey cause a sepreat hydraulic system should be reliable i guess unless ya so a seal in a caliper then ya snookerd i guess i had a look at the rta site on modifacations and i dont see nuffin about a hydraulic hand brake but shure as shootin if its not legal there it wont be legal in oz
#16 Re: brake upgrade
dimlight65 Posted on: 2002/6/16 14:50
I believe they are illegal here in the states too. Just thought I'd chime in.
« 1 (2)
