WTB: R31 skyline LSD
From Bris-Vegas
Looking for a R31 skyline Limited Slip Diff for my 1200 ute conversion.
Will pay $$$$$$$.
Posted on: 2005/2/21 0:09
Re: WTB: R31 skyline LSD
From sydney
hey dude i snaped an axle the other nite trying to decide which diff to use hilux and 9" way to heavy so its either borg warner or R31 how much abuse can the R31 take and how much cost is involved.
Cheers luke
Posted on: 2005/2/21 0:20
From Brisbane, Australia
Guys are running tens, probably nines on them by now. I bought a BW last wednesday, $110 at the wreckers, watched them cut it out (saves getting a bent one from a side/rear hit). It is being shortened and the axles resplined today. ~$400
Will also have to budget a tailshaft swap. And have to do something about the handbrakes.
Prices vary depending on what you want to do. I cut and ground all brackets off and stripped the diff, saving a few dollars.
I am also up for new bearings, rotors and pads. The ring and pinion "appear" ok. Will be chasing a 28 spline LSD also.
I have a 25spline BW LSD (hemisphere only) for sale $100. Will go into pintara diff.
The other important thing is to get the pinion angle right, basically the diff needs to be the same angle as the gearbox.
The other thing is that you can "choose" your width to suit you wheels/guards. I am going 10mm a side wider to really fill the guards. (1325mm) There are some issues here, at standard width the hand brake mechanism of the calipers will hit the leaves in the stock location. If you mount them on top of the disc you will have to bleed them off the car (no biggie). If you go too narrow, even with them on top, they will contact the upper chassis rail.
Hope this helps, and doesn't discourage.
Posted on: 2005/2/21 2:30
From Bris-Vegas
You can more or less use any diff that will fit (There's a guy up here running a V8 & 9 inch), but I'm going for the R31 as you only have to cut & re-spline one side (saves machining costs) & you also get to stay Nissan. The big problem is getting hold of one as they're getting rare.
There is also the option of getting a VL commodre diff & inserting the centres out of any late model Ford or Hoden LSD, but I'm trying to find a complete unit first to save stuffing around...........Any takers??
Posted on: 2005/2/21 6:36
From Melbourne,Australia
I got my diff done through a mate and it owes me bout a grand all up but thats including buying the diff from a wrecker then getting it shortened.Axels are 28's and have been resplined and studded too datsun stud pattern im running 4.11lsd brand new with new crown wheel and pinion and axel bearings.Shop around when you have yours done cause my mate reckons if it was for anyone else it would owe them bout twice as much.But at leat il know i wont break it in a hurry
Posted on: 2005/2/21 7:35
Quite a regular
From Sunbury, Melbourne, Australia
ey coops... go to r31skylineclub.com. they are really helpful and im sure there will be something on there for you. you can also keep your questions to the brisbane area! good luck J
oel
Posted on: 2005/2/21 7:39
Quite a regular
oel
From Bris-Vegas
thanks - 1976_datto_ute
Will give them a shot
Posted on: 2005/2/22 0:06
Coops, where in Brisbane are you?
Salisbury wreckers, $110 - Wednesday is auction day, they have new cars wednesday arvo. Give them a call after lunch to see if they have anything. They deliver!
edit: Er, that is for an open centre. . . LSD, I think they are after ~$500, but be prepared to get in line!
Posted on: 2005/2/22 0:20
From Sydney, Australia
Will you C.O.D to Sydney?
I'm running a 25 spline Commodore diff.
Cheers.
Chris
Posted on: 2005/2/22 0:21
