180b Brake mast cylinder???
From Christchurch New Zealand
First of all has anyone done this conversion before and if not what have you used????
<small>[ Edited by rally-a-coupe on 2002/6/18 17:56:32 ]</small>
Posted on: 2002/6/18 5:51
"If your not living on the edge your taking up too much space" Rod Millen
Re: 180b Brake mast cylinder???
From Invercargill, New Zealand
The early seventies rear drive Mitsi lancer master cylider is a good conversion to do.
Posted on: 2002/6/18 9:24
From Melbourne, Australia
master-cylinder from an urvan is the biggest bore if thats what ya going for, if ya make up an adaption plate it will go on a sunny booster nice
Posted on: 2002/6/18 13:23
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, Australia
I've done it..got pictures of it...and it works very well. I'll put the pictures on my webpage shortly.
I recommend Mitsubishi/Chrysler LA/LB Lancer Booster The LB Booster comes with a better booster->strut tower brace. Plus it's newer. You might need to borrow the 180b booster piston and seal (watch for the rubber disk (reaction disk) under the piston, it can get lost in the booster sometimes. To be sure of this, take a rule or tape measure with you to the yard.
It's better if you can get both from the same wrecking yard, that way no-one needs to know that you've mixed and matched.
Also make sure that you get the splitter valve from the 180B. It's the block where the lines all go into. For most applications this should match the brake master cylinder.
Chris
Posted on: 2002/6/19 0:50
From Tracy ,Ca
hi used the master cylinder from a early 300zx works great
Bob
Posted on: 2002/6/19 1:58
