« 1 (2)
Re: RPM
From Castro Valley,CA USA
How long do stock cast pistons last at 7000+?
I've always thought they fall apart after a while if reved past 6500, anything above 6500 on a regular basis would require forged.
Posted on: 2005/2/25 8:56
Re: RPM
From South Africa, Bloemfontein
ang94541
You have a good question there.
I am about to take my GX engine out at the end of the year and fully rebuild it with a balance and some 40mm sidedrafts.
If that is the case of revving too hard pistons will get damaged, I think I will keep my engine stock as here in South Africa we do not have places that make Forged pistons for our cars. I also do not want to spend a arm and a leg on Forgies.
Posted on: 2005/2/25 10:42
1977 Datsun 1200GX
Re: RPM
From Brisbane, Narangba
Cast pistons won't be a problem. Im sure alot of others will verify this. Fully balanced it will rev pretty high safely.
Posted on: 2005/2/25 10:52
Re: RPM
From Warburton vic
Hyperutactic pistons are fine. They are better for the street as they take less time to warm up. Casties all the way for a race motor
Posted on: 2005/2/25 10:57
Re: RPM
Forged pistons are justified when cast pistons will no longer hold up & i can't see that happening in a normally aspirated street engine.
I ran my 1200GX engine for a lotta years & i think i could count on one hand the number of times that it ran past 6,000. I never needed to
Posted on: 2005/2/25 11:17
Love your Datsun.
Treat it well.
« 1 (2)
