Browsing this Thread:
Need Diff Advice
From sydney
Ok guys my mate has a hilux Diff which has been already cut down to suit a 1200 ute with billet axles and a full spool. He wants to sell it to me.
The only thing is that the ute it came out of had the leaf springs moved in. Now should i go to the extent of moving my leaf springs (fairly Big Job) in which i asume is just to allow the car to run a wider rim, Or should i just modify the diff to suit the standard leaf position( pretty simple Job).
Im not interested in running massive tyres or anything.
The other thing is how hard is it to turn the hilux diff back into 4 stud.
Any help or advice would be great guys.
Cheers Luke
Posted on: 2005/3/1 3:16
Re: Need Diff Advice
From Perth
Re hang the diff......it's going to be much easier, and you already said you're not interested in big wide tyres......easy solution.
Posted on: 2005/3/1 3:35
From Melbourne Vic
yep, usually the leaf mounts are done in conjunction with mini tubs so just move them back. you can't really run a bigger rim without the tubs anyway. i have 6.5's on the back of mine and they often "chirp" on the side of the wheel tub area when going up a driveway on an angle.
as for the four stud thing, any diff place should be able to do this. about $75 each i think.
Posted on: 2005/3/1 3:51
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From sydney
Yeah sound like the way to go.
is $75 a side or per stud.
Posted on: 2005/3/1 4:14
From Campelltown,Sydney,NSW
ha man if you dont want the diff ill buy it
Posted on: 2005/3/1 4:19
From sydney
how much do you reckon its worth.
Posted on: 2005/3/1 4:34
You tell me? How much you getting it for?.. you could buy it for 1 price then sell it for another..
Posted on: 2005/3/1 4:44
From sydney
can anyone tell me what to expect from the spool never been in a car with 1 im guessing its as rought and noisy as a locker.
Posted on: 2005/3/1 5:30
From sutho shire, NSW, AUS
a spool mini or full does exactly the same thing as a welded diff. So to drive it would be exactly the same, but internally stronger than a MIG lockker.
Posted on: 2005/3/1 6:34
From Brisbane, Australia
$75 a side should do it. Spool and locker both do the same think; lock the axles together.
Posted on: 2005/3/1 6:36
