Browsing this Thread:
910 struts on 1200 lowering ratio
From Christchurch. NZ
I thought I would post that with 910 struts on 310 suspension fitted to a 1200, the ratio between the spring height and height at the wheel is 0.85:1, that means if you lower the spring 85mm, the ride height is reduced 100mm
Posted on: 2005/3/1 10:30
Re: 910 struts on 1200 lowering ratio
From Wanganui, New Zealand
When you say 310 suspension, do you mean the control arms? Its that all thats needed to fit 910 struts to a 1200?.
Thanks
Posted on: 2005/3/1 19:44
310 bottom arms, ball joints and steering arms
Posted on: 2005/3/2 9:20
