Re: another brake problem
From sydney australia
do you have the calipers on the correct side.a friend of mine,(no,not me,really),had them on the wrong sides,& couldn't get a poor pedal.the bleed nipples should be at the top of the caliper,so the air can't get trapped in the
piston.if this is correct,try bleeding the master
cylinder.the best way i've found to do this is
run the bleed line back into the reservoir,so you don't drain the reservoir & cause extra work.if
this fails,pull the hand brake on,if the pedal
gets better,bleed the rear brakes.if all this fails,
then look at the m/cylinder.
Posted on: 2005/3/2 9:49
Subject Poster Date
     another brake problem shaun 2005/3/1 9:40
       Re: another brake problem COUP1200 2005/3/1 9:46
         Re: another brake problem Dodgeman 2005/3/1 9:50
       Re: another brake problem ANGE 2005/3/1 9:54
         Re: another brake problem COUP1200 2005/3/1 10:12
           Re: another brake problem LAGWAGON 2005/3/1 10:31
             Re: another brake problem R-fastmotorsport 2005/3/1 21:04
               Re: another brake problem b310gx 2005/3/2 9:49
