Re: NIS15L went on the dyno
From brisbane
As Andrew has said the torque figure is not comparable to the figures you will see in the back of, say, MOTOR magazine when looking at new car stats because it is tractive effort not engine torque. 800NM of torque would tear the thing in half!
Regards Matty
Posted on: 2005/3/12 11:15
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Millgrove Vic OZ
edited out as this double posted through my stupidity
Posted on: 2005/3/13 7:07
Cheers Feral
The dyno was not calibrated for torque before your run I would say.
The figures you have are good for a stock Ca18DET but the torque figure does not make sense.
Horsepower is torque times engine speed divided by 5252. This means with 160.5 hp
it would be 550 times engine speed divided by 5252.
So engine speed would be (160.5*5252)/55o =1532.6 rpm
For example a typical 98 Chevy Winston Cup race engine with 12:1 CNC ported SB2 heads produces 720 HP at 7000 RPM and a maximum of 540 ft lb torque at 5500 rpm.
I calculate the torque at 6800 rpm as 160.5*5252/6800=123.9 ft/lbs torque.
Still a very respectable figure at 6800 rpm.
In a 1200 its rocket material.
Posted on: 2005/3/13 7:14
Cheers Feral
From Melbourne Vic
feral eral, now that guy knows his ####e!
go on guys, ask him a question...
Posted on: 2005/3/13 9:01
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
OK I'll go....can you please explain the difference between this "tractive effort" and "torque"?
Posted on: 2005/3/13 10:40
Torque is rotational force times the distance the force is applied at, measured at the axle centre. It is expressed in foot pounds or newton (1 kg * 9.8) metres.
Actual drive torque experienced at the tyre surface varies as pi*D proportional to tyre/wheel diameter. Larger diameter = less torque. When the torque is measured at a particular tyre size rolling surface, this is tractive effort.
Hope this helps.
Posted on: 2005/3/14 7:40
Cheers Feral
« 1 2 (3)
