Re: Hilux Diff shortened to suit 1200
the leafspring mounts will still need to be moved in.
Posted on: 2005/3/19 3:02
From Melbourne Vic
thats not a bad price, but the axles are still in five stud!
Posted on: 2005/3/19 4:18
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Canberra
PM sent
Posted on: 2005/3/19 6:52
I've just measured the diff & it is 1250mm from outside hub to outside hub.
For those people who arent aware that you will need to shorten your tailshaft to suit this setup.
This diff is also 5 stud - ford stud pattern so your standard wheels will not fit unless you reset the stud location on the axles.
Posted on: 2005/3/19 8:41
It's a Dodge /Plymouth wheel stud pattern. Thats 5 studs on a 4-1/2" pitch circle diameter [or 114 point something mm for metriphiles]
Ford copied it after it had been in continuous use for seventeen years. [since November 1931]
The true "Ford" pattern [1928 to '35, then '39 to '48] seems to have not been used by anyone else that i know about.
Posted on: 2005/3/19 8:55
Love your Datsun.
Treat it well.
Posted on: 2005/3/19 9:39
pro-12a wrote:
Haha Dont worry dude he means no harm. I think he is just worried about people forgeting Dodges History.
Posted on: 2005/3/19 9:48
I guess what irks me is the overwhelming dumbing down.
Things like the following are inacurate & misleading, but seem to become true if enough people get it wrong enough, often enough.
The object on offer here is not a diff, it's a rear axle assembly. The diff is the bit in the middle.
It has not been shortened [front to rear] It's been narrowed [side to side]
It's not a Ford pattern as Ford never invented it, used it first, or ever had exclusive use of it, they were just another adopter of it, yet the ignorant call it a Ford pattern. God only knows why.
How hard is it to get it right?
Posted on: 2005/3/19 15:10
Love your Datsun.
Treat it well.
« 1 (2)
