Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Hilux Diff shortened to suit 1200
phunkdoktaspok
Posted on: 2005/3/19 3:02
the leafspring mounts will still need to be moved in.
#12
LAGWAGON
Posted on: 2005/3/19 4:18
thats not a bad price, but the axles are still in five stud!
#14
pro-12a
Posted on: 2005/3/19 8:41
I've just measured the diff & it is 1250mm from outside hub to outside hub.
For those people who arent aware that you will need to shorten your tailshaft to suit this setup. This diff is also 5 stud - ford stud pattern so your standard wheels will not fit unless you reset the stud location on the axles.
#15
Dodgeman
Posted on: 2005/3/19 8:55
Ford copied it after it had been in continuous use for seventeen years. [since November 1931] The true "Ford" pattern [1928 to '35, then '39 to '48] seems to have not been used by anyone else that i know about.
#16
pro-12a
Posted on: 2005/3/19 9:39
Ford copied it after it had been in continuous use for seventeen years. [since November 1931] The true "Ford" pattern [1928 to '35, then '39 to '48] seems to have not been used by anyone else that i know about. ???
#17
phunkdoktaspok
Posted on: 2005/3/19 9:48
Haha Dont worry dude he means no harm. I think he is just worried about people forgeting Dodges History.
#18
Dodgeman
Posted on: 2005/3/19 15:10
I guess what irks me is the overwhelming dumbing down.
Things like the following are inacurate & misleading, but seem to become true if enough people get it wrong enough, often enough. The object on offer here is not a diff, it's a rear axle assembly. The diff is the bit in the middle. It has not been shortened [front to rear] It's been narrowed [side to side] It's not a Ford pattern as Ford never invented it, used it first, or ever had exclusive use of it, they were just another adopter of it, yet the ignorant call it a Ford pattern. God only knows why. How hard is it to get it right? You can view topic.
