Re: magic number 100hp
From Sydney Australia
su + ihi + 8.8:1 comp + porting + big valves + good turbo grind cam + big exhaust + 8 psi boost = easy 100 hp!
Which also = big clutch/pressure plate + stronger gearbox + possibly stronger diff
And don`t forget 98 octane preemo
Posted on: 2005/3/19 21:52
Normally Aspirated NO MORE !!!!
From SA the place to boost
A mate of mine had 104HP at the wheels with an A15 draw through turbo setup on 10 pounds or something like that, cheap(ish) and easy to do.
Posted on: 2005/3/20 0:09
Stanza L20 Turbo
Bluebird Series 1 FJ20ET
Bluebird Series 3 TRX CA18DET
Just put a rotary in it
A rotary would put you too far ahead of the goal.
Datsun 1200 Thought of the Day
Posted on: 2005/3/20 1:36
Quite a regular
From newcastle
if i wanted a rotary i would have brought another mazda, been there done that , never again. thanks anyway ken
Posted on: 2005/3/20 11:01
« 1 (2)
