« 1 2 (3)
#21 Re: What are the benefits of an Electronic Distributor?
dattodevil Posted on: 2005/3/23 23:31
If the original coil was using a ballast resistor, and you are still using that coil, then yes, you will have to keep using the resistor. The distributor should be 2 wire, one is ignition feed and the other is the trigger, the trigger wire is the same one that came off the original distributor.
#22 Re: What are the benefits of an Electronic Distributor?
RMSPOWER Posted on: 2005/3/24 3:48
Is the trigger wire the wire that was hooked up to the condenser? and which one of the wires from the distributer should I hook up the negetive or the positive? The colors of the wire is Blue and Black, I'm assuming that black is negetive.
#23 Re: What are the benefits of an Electronic Distributor?
dattodevil Posted on: 2005/3/24 5:54
asume nothing when it come to electronics, check the module it should show which terminal is what, it should have 'b' for battery +, and 'c' for coil. Or find yourself a wiring diagram.
#24 Re: What are the benefits of an Electronic Distributor?
Keith Posted on: 2010/7/24 21:44
Does the c go to coil + or - ?
#25 Re: What are the benefits of an Electronic Distributor?
Dodgeman Posted on: 2010/7/25 11:00
Well I finally found a downside to the use of a Pertronix electronic ignition conversion.
I fitted one to my 1200 years ago & have NEVER looked back. I have never looked at the inside of the distributor again either & that was the problem.
During routine maintainance with points one is supposed to lift the rotor button & place a drop of light oil in the hole underneath the rotor. This lubricates the distributor cam & the distributor shaft so that the mechanical advance can work properly.
Well of course without points, or the need to lift the cap & rotor, the shaft never got oiled & it eventually stuck in just one position which means that the mechanical advance function ceased to, ..... well, ..... function.
I found this when troubleshooting another problem, so I gave it a drop of oil & freed up the stuck parts. All is well again & I will perform this service task at each oil change in the future.
#26 Re: What are the benefits of an Electronic Distributor?
ddgonzal Posted on: 2010/7/25 18:24
Good to mention that. Most points distributors now have stuck or broken advance plate bearings.
For wiring, the B wire goes to the coil + terminal. The "trigger wire" which I've never seen marked that way, goes to coil negative terminal.
A condensor is not required with electronic ignition. Some cars have it as optional depending on the year etc. It won't hurt and helps with radio interference. A condensor is REQUIRED for the point set.
#27 Re: What are the benefits of an Electronic Distributor?
ddgonzal Posted on: 2010/7/25 18:57
The stock Datsun 1200 distributor wiring is:
* Black wire with white stripe (BW)
* Blue wire (L)
Blue to coil negative
BW to coil positive
For the A14 electronic distributor here is the diagram: B310 Electronic Distributor Swap, see Wiring section.
« 1 2 (3)
