« 1 (2)
Re: removing exhaust housing
If you look at the compressor nut you took off, and look at the compressor wheel and turbine wheel, you will notice they have little bits of material grinded ( removed) from them.
What are the chances you can get the nut back in the same position?
At the speed it all spins, balancing is a big thing
Posted on: 2005/3/24 12:50
From Sydney Australia
Dam I should have marked it hope there is a ridge on the shaft or something.
Anyone got any idea of how fast a turbo actually spins in relation to engine revs?
Posted on: 2005/3/24 13:00
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Me thinks it will be a bit more involved than just trying to reposition it correctly.
Posted on: 2005/3/24 14:29
From Christchurch NZ
Me thinks some turbos get up as high as 300,000 RPMs. At that speed ANY inbalance will result in catostrophic failure.
Posted on: 2005/3/24 21:35
Forced Induction!
« 1 (2)
