Browsing this Thread:
1 Anonymous Users
Re: getting header to fit |
From Millgrove Vic OZ
Michael, What part is it hitting? is it the housing around the clutch or on the steering box area?
You can dent the pipe a small amount without having any noticable effect on flow. You may be able to solve the problem by fitting two gaskets joined with silicone. Fit a circle clamp to the pipe and then make up a strut back to the block to support it.
When it goes back to the area past the collector you fit a slip joint exhaust and this allows the engine to move without stressing the exhaust.
Posted on: 2005/3/28 10:21
Cheers Feral
