Window removal
From sydney
have to get my windows removed for trimmimng just wondering if this is fairly easy and if i could do it myself or if i should pay a mobile guy to come out and do it. If so how much would i be looking at for my ute front and rear.
Cheers Luke
Posted on: 2005/3/29 6:55
Re: Window removal
From Christchurch. NZ
Just get inside and push with your feet, it should peel out nicely, to put it back in you just use some rope wrapped around, to get the rubber over the lip.
Posted on: 2005/3/29 8:36
Re: Window removal
From Ipswich,QLD
1, remove the insert on the outside rubber and corner chrome piecs
2. with 2 people sit in front with feet firmly on wind screen .push from the top of screen and peel back the rubber the screen should peel out .........DONT use shoes on the screen also find out if its laminated or
not as one cracks easier than the other
hope this helps
Posted on: 2005/3/29 9:14
Re: Window removal
the corner chromes and side cromes are fitted with the winscreen out, and shouldn't need to be removed, to get the windows in and out.
Posted on: 2005/3/29 9:44
Re: Window removal
From south australia
i got my windows out with the chrome still in the rubber
it would pay to use a blunt knife and run it around the eadge of the rubber to help free it up and if you do not have any one to healb put somthing soft on your bonet to catch the window
Posted on: 2005/3/29 10:26
