Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Pinging on Idle
Razor
Posted on: 2005/4/1 3:47
Hi
I replaced the spark plugs, dizzy points, cap, checked the idle, mixture and ignition timing (spot on)also new batch of fuel and Im still getting this pinging noise. Tried retarding the timing and same noise. Valvle clearance needs adjustment? Advise pls Cheers
#2
Re: Pinging on Idle
jozz
Posted on: 2005/4/1 4:21
Have you tired checking out your injectors?? i had the same problem but wasnt on idle, try either manually cleaning the injectors or get some injector cleaner...ALOT
#3
Re: Pinging on Idle
Razor
Posted on: 2005/4/1 4:37
HOLY ####! thats why its doing that!!!
I'm missing the injectors...must've fallen off... hehehe kidding... car is carburetted engine Weber DGV so no injectors
#4
Re: Pinging on Idle
L18_B110
Posted on: 2005/4/1 7:25
is it running rough or missing when it pings? check for excessive play in the dissy shaft.
if not, its hard to imagine how it could be pinging if the timing is correct, as you say. maybe the noise you're hearing is something other than pinging? why did you change all that stuff at once - was there a particular problem you were trying to fix?
#5
Re: Pinging on Idle
Razor
Posted on: 2005/4/3 5:43
car is not running rough or anything, its running fine when the "pinging" noise occurs.
replaced the stuff just for normal servicing... You can view topic.
