Pinging on Idle
From Brisbane
Hi
I replaced the spark plugs, dizzy points, cap, checked the idle, mixture and ignition timing (spot on)also new batch of fuel and Im still getting this pinging noise. Tried retarding the timing and same noise.
Valvle clearance needs adjustment?
Advise pls
Cheers
Posted on: 2005/4/1 3:47
Re: Pinging on Idle
From Brisbane
Have you tired checking out your injectors?? i had the same problem but wasnt on idle, try either manually cleaning the injectors or get some injector cleaner...ALOT
Posted on: 2005/4/1 4:21
Re: Pinging on Idle
From Brisbane
HOLY ####! thats why its doing that!!!
I'm missing the injectors...must've fallen off...
hehehe kidding...
car is carburetted engine Weber DGV so no injectors
Posted on: 2005/4/1 4:37
Re: Pinging on Idle
From Brisbane, Australia
is it running rough or missing when it pings? check for excessive play in the dissy shaft.
if not, its hard to imagine how it could be pinging if the timing is correct, as you say. maybe the noise you're hearing is something other than pinging?
why did you change all that stuff at once - was there a particular problem you were trying to fix?
Posted on: 2005/4/1 7:25
Re: Pinging on Idle
From Brisbane
car is not running rough or anything, its running fine when the "pinging" noise occurs.
replaced the stuff just for normal servicing...
Posted on: 2005/4/3 5:43
