Dry sumping?? a series
From Australia/ NSW/ East Maitland
Has anyone done it to an A14/A15..
if so how much and were do i get the parts from?
Cheers
Andrew..
Posted on: 2005/4/5 13:39
Re: Dry sumping?? a series
From Christchurch. NZ
Yes it has been done, thats all I know
Posted on: 2005/4/5 13:49
From Adelaide, South Australia
ARE in the states do dry sump pans for A series.
They are the only people i know of.
Posted on: 2005/4/5 13:52
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Perth
For items contact
Doug Learned at
Fast Forward
507 Redwood
Sand CIty, CA 93955
Email: interctymf@aol.com
Phone: (813) 899-3636
http://dsr.racer.net/docs/TDC_98_retail_prices.doc
Posted on: 2005/4/5 16:10
From Newscastle, Australia
mmm.... unecessary unless you are doing mini-sprint racing where the oil would be potentially one one side of the pan for a lengthy period of time.
You can ring Jeff Taylor on 02 9623 8826 and he will be able to give you a definative answer. He will probably tell you to save your $$$.
Posted on: 2005/4/5 16:12
Dont die wondering.....
From Perth
Hey Craig...is your sump baffled? Have you had a chance at all to look at oil pressure mid corner...just wondering if you get any surge at all.
Posted on: 2005/4/6 2:00
From Invercargill, New Zealand
From what I've seen of his racing lines he must spend every corner checking his gauges.
Posted on: 2005/4/6 2:07
na no baffling and I dont check my gauges at all until the cool down lap!!!
If the thing is still going I dont worry
Posted on: 2005/4/6 2:10
From Perth
hahahaha.... I hope you have your idiot light set-up properly then ;)
I don't klnow teratonga...his lines looked pretty good at Wakelfield the other week.
Posted on: 2005/4/6 2:14
From Sydney
I run an " Idiot light " on my A-series. I also use it with a 30 PSI sender. I f the light comes on with the regular sender [12 - 15 PSI from memory] at high RPM, i suggest it would a bit late by then........
I also have baffled the sump.
On a side note I saw the result of an A-Series motor, built for speedway, that had lost oil; pressure. The bearings/crank got so hot that the bearings melted back into the oil galleries of the crank. Not pretty.
Benny
Posted on: 2005/4/6 3:41
