Re: FOR SALE: A series turbo setup, 13*7" Superlites, Celica box etc etc
From Ipswich,QLD
just wondering if you gents who have photos of the intake manifold would kindly start a thread on it as I and a few other members seem to have interest in this subject...CHEERS ..........
Posted on: 2005/4/9 1:21
From Brisbane, Australia
thanks DVLDAT.
converted, I'd throw in any of those bottom ends with the turbo setup if you want. You'd probably need to chase up a set of forged pistons if you were to race it - we tried a milled down set of factory pistons with a different T25 turbo setup only running about 7 or 8psi, but cracked 3 out of the 4 skirts in exactly the same place. The rest of the A12 bottom end is fine, and was only saw a few months of running since it I rebuilt it. It had been balanced too, but that would have to done again with new pistons fitted.
To get this running should simply a matter of screwing it all together. The turbo is in good mechanical condition - the compressor and turbine wheels look fine and shaft play is good, but I cannot vouch for the condition of the seal. But there was no evidence of oil in the compressor housing when I bought it.
Posted on: 2005/4/9 2:20
From Perth
Ok more questions
Whats its physical dimensions and weight? Just thinking freight to Perth here.
I don't think I'd need the radiator.
Any price flexibility ?
Posted on: 2005/4/9 9:04
From newcastle, NSW
Is this Craig's set up? or a different one?
Posted on: 2005/4/10 1:28
The manifolds, turbo, wastegate, carb, and dump pipe weigh in at 15kg - the turbo is the heavy part! I don't know what all the other stuff weighs.
Steveo, its a different setup. Bigger turbo, external wastegate, better manifold design and extra things like the cam (Craig ran a std cam), oil cooler etc.
Posted on: 2005/4/10 7:30
« 1 (2)
