From Sydney, Australia
Damo: NO Utes came with an Auto.
Choices:
L24 R30 Stumpy Skyline 5 speed with S3 Bluebird (CA20) or S13 bellhousing, needs different sized bearing in box to interface. $400-$500 (assembled by yourself)
S3 CA20 gearbox (weak) $100
Import Gazelle Gearbox (rare), but the best option for position of shifter and strength. Basically a shorter version of the S13 box. $500+
S13 Gearbox - Too far back in a ute. $200
The Auto Tunnel will fit the larger CA style bellhousing, but not the shifter end. A box section is required. The Manual tunnel will JUST fit the stumpy skyline box, you'll need to remove the STD gearbox mounts on the body. The same shifter end box section will be required. In a ute, the handbrake may need to be relocated, if any of the long gearbox options are used. In a Sedan, Coupe, Wagon, the handbrake is just moved backwards, and a Ute handbrake front cable is used. The Ute runs out of space.
If you can't make the crossmember yourself, you'll have little chance of success in doing the other more difficult facets of the conversion yourself.
I've seen 10 years of people asking about this conversion. I've seen many projects fall short due to excess of expectation with a deficiency in skills/budget.
A difficult conversion is like a bad girlfriend.. You can pour heaps of money into it, and end up unhappy, in debt, and find yourself driving a VN Commodore because thats all you can afford.
Posted on: 2005/4/12 0:25
