Browsing this Thread:
1 Anonymous Users
Turbo pistons? |
From St. Helens, Oregon
Does anybody know if pistons from a turbo E15 will work in an A15? If not then what should I do in order to lower the compression to an adequate ratio for 6-7lbs of boost? I've tried to find a head shim but I cant and I even work at an auto parts store. If anybody can help me it would be great and much appreciated. Thanx sonofDAT
Posted on: 2005/4/19 6:21
Re: Turbo pistons? |
From WA
for 7psi i wouldn't even bother lowering the static CR. just use good quality cast pistons (ACL or HE) and they'll last with good tuning.
Posted on: 2005/4/19 6:51
From Northern NSW
man ill be runnin 5 psi soon andi reckon a good rebuild with stock pistons good expensive rings and bearings and a very nice new exxpensive head gasket and inlet/exhaust gasket ....u wont have any problems thats what ive done and apparently this should be fine for only the low boost settings
Posted on: 2005/4/19 11:46
dato ute (see avatar) a14 blowthrough turbo motor
Import Auto Parts For all your jap performance parts and accessories pm for availabilty and quotes
