handling problems
From gold coast QLD australia
OOOPS.MATTS emaculate 120y at MT cotton 05/12/04 to twisted to fix, new 120y sedan nearly completed (he had just fitted control slicks after running on radials all year and forgot the car would actualy turn into the corner when he turned the wheel..
SLY OLD FOX..........Open in new window
Posted on: 2005/4/25 14:48
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
Re: handling problems
im guessin this is the part were every one goes.. AWWWWWWWW
man thats a shame, that looks like a shmick ass 120y wagon.
whats it running?
is he striping it for parts.. coz i need some stanza struts ??
Posted on: 2005/4/25 15:59
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From Melbourne Vic
dam! is that a 1200 wagon? any more details about it?
cheers
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
the 120y has already been striped and all the mechanicles have been swapped to his new 120y sedan which he is now painting.the shell was to badly twisted to fix.the engine is 1270cc slightly ported oval port head(std valves and springs)32-36 webber extractors,mild cam which produces 106hp at the wheels.4 speed sunny box and std borgwarner rear end,cut down Y struts and stiffend,runs the girlock brakes all round(slightly larger than jap brakes.std front sway bar and 40mm lowering blocks on rear 13x6rims whith cotrol slicks.has adjustable top strut towers and runs 2.5 neg camber.car should be ready for june sprints at morgan park.
Posted on: 2005/4/26 6:18
From Brisbane, Australia
it was a shame to see the wagon end up like that - as you say it was immaculate. The straightest 120Y wagon I've ever seen.
At least he's done something about the suspension for the new car! even if it is cut 120Y coils and lowering blocks, the lower Cg and camber will definitely help! Personally I'd suggest upgrading the springs front and resetting the rear to increase spring rate and to do away with the lowering blocks.
Posted on: 2005/4/26 6:37
sounds like a mild beast.
does ne one know about some cheap stanza struts?
Posted on: 2005/4/26 6:38
woodydat.dont know of any i shortened the struts by 50mm and had the inserts shortened and stiffend by joel at struts r us in nerang,he is into motor sports and was keen to do what i asked him to do in the way of stiffness.
Posted on: 2005/4/26 7:18
yeah, i need stanza struts for my ute. the struts i have now are rat ####, and i want front end disc brakes. thats all.
Posted on: 2005/4/26 9:51
